Help needed! Tach troubles
Old Jan 12, 2006 | 05:13 PM
pawel's Avatar
pawel
Hey
I've got a 1995 f-150 4.9L standars pickup that I'm trying to put a tachometer in. I Have an aftermarket tach thats a good quality 1 but I'm having alot of trouble hooking it up.
The instructions are kinda vague, and I have the pos neg and backlight wire hooked up ok but the green tach signal wire is causing problems as in where does it go?
I don't seem to have a tach signal wire like it says I should have... am I missing something... I just hope I don't have to buy a tach adapter :>( b/c I'm 19 and every bit counts
If anyone has a picture of what it shoudl look like or something that would be a great help.... I just cant figure where it should go
thanks in advance,
Paul
Old Jan 12, 2006 | 05:33 PM
mhg's Avatar
mhg
tach signal wire is the negative side of the coil
the side that goes to the dist.
