6 volt to 12 volt conversion
Old Jan 12, 2006 | 11:30 AM
low54's Avatar
low54
Fella's I've a 239cid, in a '54, I'd appreciate any insight on conversion's or links for "dummies," like myself...thanks
Old Jan 12, 2006 | 11:56 AM
Scott123's Avatar
Scott123
This is a start, not a whole lot of detail but it'll get you going: http://www.patricksantiquecars.com/articles.htm
If you google "6 volt to 12 volt conversion" you will find several different articles on it. Personal opinion this conversion is one of the best things you can do for your vehicle.
Make sure your wiring harness is good, if not, this conversion is the time to do it. I pinned my harness to a sheet of plywood on sawhorses, and went through it thoroughly, soldering ends on, fixing anything that looked like it needed it, cutting out the voltage regulator and generator wires and adding in wires for electric fan and altenator, etc, and re-wrapped it all with new tape. Worked out very nicely.
Scott
Old Jan 12, 2006 | 12:10 PM
low54's Avatar
low54
thanks scott I'll get on it and let you know the outcome!
Old Jan 13, 2006 | 08:10 AM
rogerf100's Avatar
rogerf100
Thumbs up
All the info you need in a nice little book, just 20 pages of light reading.
http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.346/display_id.2867/qx/Product.htm
