93' 4.9 F150. Dailey routine.Truck starts right up,drive to store,comeout 10 min later and turns over but only starts after 3-4 times turning on key.After realizing fuel pump was not activating on the failed attempts, I found no power to either front or back pump when this occures.Backtracted wiring and found also no spark at engine. Replaced pickup in dist.and elec.ignition module.Experienced this everyday for last 5-6 weeks.
Doesn't appear to be fuel problem.Fuel pumps come on when I get power to them,and truck will start. Problem is I have to turn on key 3-4 times sometimes to get fire at engine or power to wiring at pumps.What besides pick-up in dist. or elec.ignition module could be affecting both?
Might try swapping the PCM Power Relay with one of the other relays and if that does not work you may have to look underneath at the wiring going to the pins of the relays.
