Coil Resistance
Old Jan 11, 2006 | 10:56 PM
fivestring63's Avatar
fivestring63
Coil Resistance
Had a little time to kill and was checking primary coil resistance. Manual says it should be between .8 to 1.6. I'm getting 1.7. Bad enough to change?? Runs fine.
Old Jan 12, 2006 | 08:41 AM
subford's Avatar
subford
No, do not change it. A little more is OK as wires inside the coil do not increase in resistance (only connections to the wires).
You need to be worried if it is less then .8 (or whatever it was when installed) as that would be a short.
The only sure way to test a coil (any coil) is to ring it and watch the oscillations (cycles) on an oscilloscope.
outdoorfan
Mar 17, 2018 12:07 PM
radracer17
Apr 10, 2015 04:23 AM
351Cleveland C4
Feb 6, 2014 06:39 PM
FordFanForever
Modular V8 (4.6L, 5.4L)
16
Mar 5, 2011 12:53 PM
