Alternator problem??
Old Jan 11, 2006 | 06:49 PM
OH_FARMER's Avatar
OH_FARMER
Question Alternator problem??
After replacing the battery, I notice the small battery light on the instrument panel stays lit for a few seconds after the truck starts. Being a new ford owner, I'm not sure what this means. The truck is a '94 f-450 with 460 motor. Anyone have any thoughts?
Old Jan 11, 2006 | 07:42 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 11, 2006 | 09:28 PM
subford's Avatar
subford
That sounds about right, you might check the battery voltage at the battery with it running. It should be about 13.5 to 14.5 Volts.
Old Jan 12, 2006 | 09:02 AM
GWall's Avatar
GWall
Put a charger on the battery to ensure that it is fully charged. Instructions with some Ford alternators state that the battery must be at full charge for the new alternator to work correctly.
Old Jan 12, 2006 | 10:13 AM
frederic's Avatar
frederic
This also seems to vary from truck to truck. My friend's F150 does this... you start the truck and the voltage gauge moves at a medium speed to where it should be, as does the voltmeter I put across his battery out of curiosity.
My crewcab on the other hand, once the engine catches it zooms right up to 1000 RPM during warm up and the voltage gauge "snaps" to 13.7 V and stays there "no matter what", verified with a voltmeter across the battery of course.
I wouldn't worry about this, unless the check engine light and the voltmeter swing down when you're idling.
