1978 - 1996 Big Bronco
new here. speedometer problem.
Old Jan 11, 2006 | 06:21 PM
jackcoultier's Avatar
jackcoultier
Question new here. speedometer problem.
Hey fellow enthusiasts. i am new here and I have a problem. i own a 94 ford bronco. when i press the gas pedal the speedometer shoots all the way right to maximum speed even if im going 5 miles an hour. i havent changed or modified anything. i bought it this way. any help would be apreciated.
Old Jan 11, 2006 | 06:23 PM
andym's Avatar
andym
The VSS is on top of the differential. One bolt holds it in place, and there are two wires coming out of it. Pull it out and wipe it off with a rag. If that doesn't fix the problem, you'll need a new PSOM, which is bascially the speedometer in the dash.
Old Jan 11, 2006 | 06:26 PM
jackcoultier
thanks i will try it out. i knew coming here would help.
