Sponsored by: Kumho
brake line location
Old Jan 11, 2006 | 04:56 PM
fordsrgrt's Avatar
fordsrgrt
brake line location
replaced my brakes on my 74 highboy /drum brakes all around.after bleeding pedal is hitting something ,wont go to the floor ,so pulled master cylinder to see if it was linkage or power booster ,its not so must be master cylinder. also checked booster rod length pretty close to specs. on my master cylinder the rear line is to the front chamber and back to the front,yet on the master cylinders at parts house the adapters are set up to have the lines reversed so does it matter which chamber they go too?
