Wiring:-
Old Sep 24, 2001 | 02:36 PM
beartracks's Avatar
beartracks
Wiring:-
Old Sep 27, 2001 | 04:45 PM
mclzr's Avatar
mclzr
Wiring:-
I'm trying to hook up a back-up lite using (one) fog lite.I've got both wires from the light running to my toggle and I spliced in the hot wire from the battery.I've got power on both sides of the toggle,and at the light.Should'nt one be hot, other the grnd? When I hooked the grnd wire to the frame, the lite came on, but would'nt shut off at the toggle.I then un-hooked the grnd off the frame, then the light would'nt work .Whats wrong???I'm using a (2) prong toggle.I'm about to pull my hair out!!
Old Sep 27, 2001 | 05:24 PM
BB's Avatar
BB
Wiring:-
I don’t understand why you have both wires from the light running to the switch. One wire should be always grounded to the frame and the other wire hooks up to the switch. The hot wire hooks up to the other side of the switch. The current flows from the battery into one pin of the switch, out the other pin of the switch (when switched on)and then to the bulb. The return current comes out of the bulb and to the frame back to the battery.
Barry
Old Sep 27, 2001 | 11:30 PM
mclzr's Avatar
mclzr
Wiring:-
Thank you Barry for the info.the instr; on the toggle switch said to wire it that way. Going to do it your way in A.M..Thank-you!
Old Sep 30, 2001 | 09:13 PM
mclzr's Avatar
mclzr
Wiring:-
I got it working, so thanks alot for the info!! KEEP ON TRUCKING!!!
