I'm rebuilding a 302, but the block i'm using is a Mercury block, does have numbers on it, know of any site i can decode it at? The Ford/Mercury engine block is D2OE-AB, with E5AE-CA heads, if you have any information on this block or these heads, it would be very helpful.
Thanks
Dustin
The casting #'s on the heads is on the bottom of the head, you have to take it off to see it. The casting #'s for the block are on the side of the engine where the starter is, towards the back of the block, i think you have to take the starter off to see them. I know that on my 302's that everything was off so it was no big deal for me, here is a link that shows you where they are at. http://www.aacncclub.com/FORD_HEAD_CASTING.html
Hope this helps you.
I was wondering, my 1972 302 is a "Mexico" block, did Mercury Marine engines just come off the same plant?
I looked at my block an read F1SE and 2L16.. On the block it looks like FlSE and 2Ll6 so Im not sure if it's a #1 in the ID.. I don't know if I looked in the right place, on the right rear side of the block down near the oil pan??
F1SE would be a '91, the second number you list looks like the date code which is the actual date the block was cast. 2 is for the year (since we already know the decade from the casting number = F is for the '90s) and L is for November. The last two are the day and it should indeed be a 1, so it's November 16 1992. Just right for a '93 model.
What would this be E7TE there is also a CA below it. I didn't look for the other #'s. This is another engine I have it's out off an Ex Trooper car or so I've been told.
The E7TE heads are truck heads that were used from 1987- 1996 I beleive on all trucks with EFI. Most have a combustion chamber of 64CC and use 1.78 Intake valves and 1.45 Exhaust valves.
Opps, sorry Wakojoe, its still an 87 casting. E=1980's 7=the year T=Truck E=Engine part. Not sure how many years Ford used that block for production, but thats not really important. The main thing is its a 87 block. My 91 Bronco has an E7TE-CA block with E7TE heads.
Dustin
The best way to tell if its a Mexican Block is to look for the 2 humps in the front of the motor, one on each side towards the top right below where the heads attach.
And in the lifter galley there will be a "M" or "Hecho en Mexico" stamped in the middle of the galley.
