Bronco II Ford Bronco II
Most Reliable Engine Swap?
Old Jan 11, 2006 | 08:32 AM
OSin86's Avatar
OSin86
Just curious what would make your list. If you were going to put any Ford motor in a BII, reguardless of power (big or small), what one would you pick?
Old Jan 11, 2006 | 05:27 PM
oppy's Avatar
oppy
4.0 hands down. By far the easiest to do, and lots of bang for your buck!
Old Jan 11, 2006 | 09:17 PM
paintstuff7's Avatar
paintstuff7
I'd have to agree with the 4.0 I have an 87 putting a 98 4.0 into it, Have harness and comp issues , but can deal with that
Old Jan 12, 2006 | 04:27 PM
OSin86's Avatar
OSin86
Thanks for the responces guys. What do you think of the other direction, like a 2.3L?
Old Jan 12, 2006 | 04:42 PM
paintstuff7
WHY? Isn't bigger better.I never thought about going the other way. My 4.0 Exploder has been very good to me so the 4.0 was an easy decision for me.Either that or my clevland. Don,t really want to go there.
Old Jan 12, 2006 | 05:20 PM
OSin86's Avatar
OSin86
Well bigger is better I guess but I don't plan on turning her into a mosnter and if I wanted to have fun I could bolt on a turbo unit and get more hp with that 2.3 then the 4.0's put out. Now that sounds like fun........ a turbo 2.3L BII?
Old Jan 12, 2006 | 07:05 PM
oppy's Avatar
oppy
Well, I suppose anything that was once in a Ranger should theoretically fit in a B2. Like any swap, the key would be to get all of the electronic stuff too - computer and all the wiring (including underdash).
I'd be a little concerned about the available transmission choices though.
Good luck with your swap. Keep us posted!
Old Jan 12, 2006 | 07:20 PM
OSin86's Avatar
OSin86
Checked on the tranny, looks like the 2.3 belhousing and clutch I have now will bolt right up to my FM146. IDK for sure tho. LOL, if I fix my 2.9 it might be a while anyway. These BII's are just too cool.
I guess I started this thread more for interest anyway. Always cool to hear what people are installing in them.
Old Jan 13, 2006 | 04:08 AM
rebocardo's Avatar
rebocardo
302 with Duraspark (or a points dist fitted with the Pertronix II) and Edelbrock 4 bbl carb backed by a 5 speed with a 2" body lift. A very popular swap.
Old Jan 13, 2006 | 08:08 AM
oppy's Avatar
oppy
5.0 swap is popular, but if I was going to go through all the effort to do it, I'd use an EFI setup. Yes, it's more work, but much more reliable.
Old Jan 13, 2006 | 12:35 PM
rebocardo's Avatar
rebocardo
I disagree, especially for anything that takes a TFI module. If it was DIS then I might agree somewhat. Since I take my vehicles off road, I find the setup much more reliable, especially since I do not like taking my expensive code scanner with me.
Old Jan 13, 2006 | 10:06 PM
oppy's Avatar
oppy
Guess we'll hafta disagree on that one. I wheel a lot and the guys that have problems are almost always the carbureted rigs.
Old Jan 16, 2006 | 08:20 PM
MattMatt's Avatar
MattMatt
A lot of guys are putting 4.0 in there B2 but I'd like to have a 302 in mine. just my 2 cents.
Old Mar 5, 2006 | 10:50 AM
bronco2forever's Avatar
bronco2forever
I just signed in on this thread & looking info on a complete engine/auto tranny swap in my 88 BII 4x4. Would like to replace the 2.9 with 4.0 along with the tranny. (My tranny is toast and 2.9 coughing badly at 215,000 miles plus 35,000 towed behind motor home) If I found donor two wheel drive vehicle, will my MANUAL transfer case adapt to the tranny? Reading other comments here tell me a rolled over Explorer might be my best bet. What say you ? I ain't NO MAKANIC, but usually can turn the nut in the right direction. .../gene
Old Mar 5, 2006 | 07:42 PM
Ken00's Avatar
Ken00
Please respond to bronco2forever's question in this thread....
https://www.ford-trucks.com/forums/s...d.php?t=468820
