EGR plug
Old Jan 11, 2006 | 12:56 AM
JLG ANGUS's Avatar
JLG ANGUS
EGR plug
Just a quick question. With my egr unplugged i should not have a problem with buildup or the valve sticking. I know this might sound dumb just need some reasurance.
Old Jan 11, 2006 | 04:25 PM
kw5413's Avatar
kw5413
With your EGR Valve unplugged in the closed position you will still get a certain amount of residue that will leach to and build up around the valve.
Mine was unplugged for 16K - 17K miles. I plugged it back in, cleared the codes and drove for about another 400 miles with no problems.
I did all this to get her ready for a recall. Low and behold the dealer replaced the EGR valve any way. Mainly because it was the original and not the new improved version.
Left the new one pugged in for about 500 miles to see if I got any enhanced performance or MPG gains. ...None noted. Unplugged new EGR Valve and turbo lag was reduced again. Go figure.
Still happily unplugged at 26,000 miles.
Old Jan 15, 2006 | 11:34 PM
big ride's Avatar
big ride
Question unplugged, have some ???
Took the leap and unplugged MY EGR valve today. Key was off, pushed the clutch, started the truck, and WOW was it ever quiet! Almost sounded like it was running on 93 octane Super unleaded gasoline.. hehe.
My questions are as follows...........
1. With valve unplugged, should the valve itself and/or the connector that was removed be either capped, or covered to prevent any contamination?
2. I scrolled through the digital readout options on the dash (setup/info) and got to "Diag. Trbl. Codes: None"... is this telling me that unplugging valve did NOT set any codes?
3. 1805 is in the near future.... when I go to load programs, will they load properly, or will I have to start w/ valve plugged in (in stock form)?
TYVM for the unput............................. 'BR'
