Sponsored by: Kumho
replacing tie rods
Old Jan 10, 2006 | 06:45 PM
dpbike403's Avatar
dpbike403
replacing tie rods
My 88 f-150 needs a passenger side tie rod replaced.Should I replace both sides at the same time? I think I should have both sides done at the same time but my mechanic says the other side is fine. I hate to have it aligned and then have to replace the other side in a year or so.The truck has 52,000 miles and I drive it on the hwy mostly. Thanks
Old Jan 10, 2006 | 07:55 PM
frdtruc1's Avatar
frdtruc1
I have been advised if you are replacing one, replace both. I don't know if lower milage would make any difference, but you have 52,000 on each of them, why not start fresh with both being new. I will watch for others to respond as I plan to do that same job this weekend.
Frank
89 /F150
Old Jan 11, 2006 | 06:01 PM
SRD4X4's Avatar
SRD4X4
If they're the factory "rubberized"type, I would replace both outers and left inner.On that particular style,age is more of a factor than mileage.
Old Jan 12, 2006 | 10:44 PM
someday's Avatar
someday
either just replace the bad one or replace them all (4 total)
Old Jan 13, 2006 | 01:00 AM
mattd17's Avatar
mattd17
i agree.... since you are going to need another alignment anyhow, just do them all and save yourself the hassle later. the extra money you spend now plus one alignment will be cheaper than doing an alignment everytime you replace a single part.
Old Jan 13, 2006 | 01:59 AM
someday's Avatar
someday
i would at least buy one with a lifetime warranty from most any part store
Old Jan 13, 2006 | 09:15 AM
dpbike403's Avatar
dpbike403
Thanks for the replies...I'm going to have them all done at the same time.I plan on keeping the truck for a long time.
