engine making noise
Old Jan 10, 2006 | 04:02 PM
Fordman79's Avatar
Fordman79
engine making noise
the engine in my 79 started making an odd noise while I was driving it. it sounds like a pinging. i asked a couple a people there opinions one said it sound like it was coming from the bottom end. could be a spun bearing he says. the other guy thinks it could be a valve or a stuck lifter. What do you think.
Old Jan 10, 2006 | 04:12 PM
Mil1ion's Avatar
Mil1ion
Pinging is from the upper cylinder area.
Clunking is from the crank area.
2 different type sounds.
You will hear bottom end clunk better with the engine under load.
Old Jan 10, 2006 | 04:17 PM
Fordman79's Avatar
Fordman79
thanks for the info
Old Jan 10, 2006 | 06:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check with your engine forum for more specific info.
Old Jan 11, 2006 | 09:28 PM
trinogt's Avatar
trinogt
A cold startup will usually really show a failing bottom end, as there is no oil pressure when you first start. But as mil1ion said, the sound needs to be confined to either top end or bottom.
I knew a guy with a 5.0 in a truck and went for a ride with him. I heard a knocking kind of noise and told him the bottom end is about to go. He said no, that it was just the plastic gravel shield underneath flapping in the wind.
A few weeks later, a rod came out the side of the block.
Either way, find out soon. You may be turning a rebuildable core into a boat anchor.
Mark
Old Jan 12, 2006 | 04:10 PM
Fordman79's Avatar
Fordman79
it was just low on oil. I changed oil it to be sure that no metal particals in the oil, and the was none.
Old Jan 12, 2006 | 04:15 PM
derherr65's Avatar
derherr65
Ummm, it's usually best not to check your oil level by waiting until it runs out. That practice leads to situations like trinogt mentioned.
Old Jan 12, 2006 | 04:18 PM
ford390gashog's Avatar
ford390gashog
Old Jan 17, 2006 | 04:15 PM
Fordman79's Avatar
Fordman79
I'll be more carefull from now on.
