Normal knocking in a cold engine?
Old Jan 9, 2006 | 11:43 PM
tdford's Avatar
tdford
I'm on the 3rd 7.3 in my 91 F350 and have about 4000 miles since the install. This engine seems really noisy compared to my other engines when I first start it up but quiets down as soon as it warms up and seems to run really well. If I had a gasser making this much racket I'd check the timing first thing but the timing was set by a diesel shop so is there something else I should check or could the knocking at cold starts be "normal" for this engine?
Old Jan 10, 2006 | 06:00 AM
PLC7.3's Avatar
PLC7.3
There should be considerable "Rattle" due to timing advance and cold engine. It should as you say quieten down once fast idle and timing advance go off. However a really quiet engine would signify too far retarded timing, yours sounds to be operating ok.
