Ford 15" inch specs?
Old Oct 3, 2001 | 02:47 PM
Jermafenser's Avatar
Jermafenser
I want to put bigger tires than the factory speificied which are 235/75-15.
Does anyone know the specs on this factory rims, such as backspacking, measurements of the inner/outer rims, bolt patterns, all that??
Old Oct 6, 2001 | 12:50 AM
gadams's Avatar
gadams
Depending on which year, I'm pretty sure the bolt pattern is 5x5.5
Greg
67 F100 CCS 390 cruise-o
Old Oct 7, 2001 | 07:16 PM
79fordslug's Avatar
79fordslug
they are 5x5.5. The stock wheel is either 5.5" or 6" wide. I upgraded last year to a 15x8" white wagon wheel(you know the one) with General Grabber ST tires, size 31x10.5 on my 2wd truck. No problems with rubbing at all. You could probably put a 10" on the back, but it would rub if you went that wide on the front.
Old Oct 7, 2001 | 07:29 PM
mamayek's Avatar
mamayek
