oil drain plug leaks
Old Jan 9, 2006 | 11:18 PM
jcab's Avatar
jcab
I have a 97 diesel that leaks at the drain plug for the oil. The plug is tightly threaded in hole. I went to the auto parts store and they sold me another metal washer. I don't think this will fix the leak. Any other ideas that might work? Thanks Jeff
Old Jan 9, 2006 | 11:21 PM
ford390gashog's Avatar
ford390gashog
a new washer will work.
Old Jan 10, 2006 | 08:07 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A new washer usually does the trick.
Old Mar 27, 2006 | 02:00 PM
rallynutdon's Avatar
rallynutdon
I used a new crush washer (not just a flat one) on mine and it still leaks. My previous oil change I used a new flat washer and it leaked. Seems as if it's leaking past the washer somehow. Of course, now that there's 14 quarts of oil in, there's nothing much I can do about checking the hole more closely until the next oil change. Which won't be for a while since I don't put a lot of mileage on it. Anyone had this problem and tried a completely new plug?
Old Mar 27, 2006 | 07:15 PM
cookie88's Avatar
cookie88
FTE Emeritus
How much torque are you puttng on the plug? Maybe it isn't tight enough?
Old Mar 27, 2006 | 07:22 PM
dew487's Avatar
dew487
I had the same problem. Solved it by getting a new copper washer from the Ford dealer. I think it cost about $1.50.
