idle rpm question
Old Jan 9, 2006 | 10:04 PM
Turbo_Whistler's Avatar
Turbo_Whistler
idle rpm question
Quick question. What should the engine rpms be during idle after the motor is warmed up?? My engine idles at about 650 rpm when warmed up, is this correct?? Seems like its loping a little more than it used to. Thanks.
Old Jan 9, 2006 | 10:27 PM
jtharvey's Avatar
jtharvey
I thought mine was more like 750 or 800 rpm. When was the last time you replaced your CPS? Do you think that may be a culprit? What about the fuel filter; is it fresh? One more, do you know what your fuel pressure is?
Old Jan 9, 2006 | 11:39 PM
Turbo_Whistler
Put a new cps in 4 days ago, also has a new pedal assembly with the idle and throttle sensors. Put these in after having some real crazy jumping rpm problems. Havn't checked fuel filter latley, but it was changed about 8 months ago. Don't know fuel pressure. After doing some searches i am thinking about looking into a new ICP sensor or atleast checking mine.
Anybody else know what the warm engine rpm should be?
Old Jan 10, 2006 | 12:20 AM
twags6's Avatar
twags6
650 is within the specs I found. It shows idle between 600-800 rpms
Old Jan 10, 2006 | 12:24 AM
jtharvey's Avatar
jtharvey
It might not be your problem, but that fuel filter may be due for a change, depending on how many miles you have on it. I usually change mine every 6000-7500 miles.
Old Jan 10, 2006 | 07:07 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i plug my evolution in when warm and it fluctuates from 695-715. however the tach shows 720-740rpm
