Your best bet is to remove one yourself from a junkyard truck with the same motor/ trans. combination as yours and as close to the same year as yours.
If yours has the above gas pedal computer and tfi ignition, make sure your donor is the same.
Also note cruise control, A/C, power windows, etc.
Bring along masking tape and a felt tip marker.
Go slow, pay attention, label everything.
This is a job that seperates the men from the boys!
The good thing about removing 2 harnesses from 2 vehicles bofore installing your new undamaged one in your truck is that it will be ingrained in your memory how to put it back in properly.
Good luck!
Steve G.
