Steering wheel removal
Old Oct 8, 2001 | 09:44 PM
Danlaws's Avatar
Danlaws
I'm having trouble getting the steering wheel off my 69 F100. Got the horn button off, got the nut off the center but my puller won't budge the thing. Is there a trick I'm missing?
Old Oct 8, 2001 | 10:03 PM
chripark's Avatar
chripark
I have made taking my steering wheel off a common event around my house lately. I had to change the turn signal switch out and I am still trying to fix my horn. I used an ordinary steering wheel puller to get mine off. I threaded the two bolts in and then started cranking on the center bolt. It took a little elbow grease the first time to get it off, but now it pops right off. I would suggest keep on keeping on. Maybe take some WD40 and spray on the wheel and let it sit for a night and then try the next day?????? Good Luck!
Old Oct 9, 2001 | 06:47 AM
jowilker's Avatar
jowilker
Dan, Keep cranking on the center bolt, it'll pop loose. :-)
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old Oct 9, 2001 | 09:49 AM
beartracks's Avatar
beartracks
You might be able to tap on the puller through bolt with a hammer but dont get too carried away.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Oct 9, 2001 | 10:51 AM
benford's Avatar
benford
I had trouble with the through bolt on the puller slipping off the steering shaft, so I put a shallow socket over the steering shaft to keep it from slipping, I think it was a 3/4 socket , worked like a charm,
Old Oct 9, 2001 | 11:48 AM
jon69f250's Avatar
jon69f250
jwford
2004 - 2008 F150
Jun 11, 2011 10:23 AM
jade79
Apr 28, 2010 10:47 AM
natecousineau
Mar 22, 2008 03:31 PM
CWR
Jun 26, 2003 09:40 AM
redvet
May 13, 2003 12:27 PM
