Swapping 300 for 302 CFI
I am a "use what you got" kind of guy, and have an 84 Crown Vic Wagon with the throttle body injection (CFI as Ford called it). I'm gonna swap that into the truck for various reasons. The car is junk, and I use my truck for rockcrawling, etc.., so fuel injection would be nice. It will mate to a T18 4 speed.
Now that you know most of the story, what all do I need to make this work as far as bolting things up? Motor mounts? Clutch stuff? I'm not worrying as much about the electrical, as we can get that all worked out, but was curious mostly about mounts and what I need for the clutch to work.
I know the 300 is better for torque, but not worried about that at this point. The gearing is low enough that I have plenty of torque to crawl, plus I'd like to keep the power down so I will have a harder time snapping axle shafts with a spool/locker in the axles.
Thanks all.
T
Besides the obvious wiring fun, the only things I can see that would be a prob would be the oilpan (need a truck pan a pick up tube), rubber motor mounts for the engine, and exhaust....
