How much can I tow???
Old Jan 9, 2006 | 12:54 PM
Battleaxe21's Avatar
Battleaxe21
New to forum and new to Ford world of Trucks.. Just purchased a 2002 F-250 with 7.3L Diesel, Has Banks Turbo, Banks Stainless Steel exhaust, exhaust break, K& N and Firestone airbags.... Crew Cab Long bed... Also has transmission cooler... (4 spd auto). Built to TOW
Looking to get into 5th wheel RV world...Any thoughts on how much of an RV I can safely handle....Looked this past weekend at a show...lots of 5th wheels...several different weights
Thanks in advance for helping someone new to the Ford world out.
Old Jan 9, 2006 | 06:23 PM
trike1946's Avatar
trike1946
Welcome to FTE. What rear ratio do you have? 2x4 or 4x4?
Old Jan 9, 2006 | 06:41 PM
The SnoMan's Avatar
The SnoMan
Tire size too
Old Jan 9, 2006 | 07:22 PM
James Hewett's Avatar
James Hewett
I pull a 5ver that weighs 8900lbs. at 1st I did it with a 5.4, it seamed ok at first until I started climbing hills and mountains, the gas milage dropped off and so did the speed.
You probably got what it takes to climb mountains comfortly with a 11,000 lbs. I don't know about the legal end of that is.
Another thing to think about how tall you truck is, because you need it to ride level and the trailer level too, with 4to6inch clearence between the 2 on top of the p/u bed, depending whay kind of terrain you travel on, like going across the slope of a racetrack from the outside to the lower of the track surface.The landgeer will scape on the top of the hill and the very nose of the trailer will hit the top of the bed as you start to levelout.Camping in the infield is best!
Old Jan 9, 2006 | 07:36 PM
The SnoMan's Avatar
The SnoMan
If he has the correct tire size and axle combo maybe.
