transmission compatibility
Old Jan 9, 2006 | 11:27 AM
ajcal225's Avatar
ajcal225
Do the 385 blocks and FE blocks share a bolt pattern for transmissions?
I've scored an allison 545 off of a 370, and am interested in running it with a 390 FE block..
Old Jan 9, 2006 | 12:51 PM
monsterbaby's Avatar
monsterbaby
in short NO
Old Jan 9, 2006 | 12:54 PM
ivanribic's Avatar
ivanribic
No, they require different bellhousings. If I remember right the 460/429 uses the same bellhousing as the 400 and 351m. FE's use their own bolt patter/bellhousing.
Old Jan 9, 2006 | 01:20 PM
ajcal225's Avatar
ajcal225
Thanks.
Old Jan 10, 2006 | 05:12 PM
deerhunter3814's Avatar
deerhunter3814
He said he has a transmission off a 370.
So is the bellhousing bolt pattern the same on the 370 and 429/460?
The three engines share other simularties.
I just noticed he said he was putting it on a 390.
But I would like to know if the bellhousings are the same on the three. (I know the 429/460 are.
Thanks
Old Mar 30, 2006 | 02:43 AM
darrin1999's Avatar
darrin1999
yep
yes the 370, 429, 460, 400 and 351m all share bell housing bolt patterns
