auto trans?
Old Jan 9, 2006 | 05:59 AM
cwalsh540's Avatar
cwalsh540
auto trans?
i have a '66 f100 with a newer 300 and a 3 on the tree. the trans it about shot. i was wondering if there is a good 4 speed auto that would bolt in with not too much work.i am mecanicly inclined so the work is not a problem but if anyone knew any websites with new mounts or whatever and could point me in that direction. i know you guy will tell me to rebuild the tran but i am over all the shifting. all of my cars, trucks and bike are shifts so i just want to cruise.
thanks in advance
chris
Old Jan 9, 2006 | 06:03 AM
ford390gashog's Avatar
ford390gashog
you can make a E4OD work
Old Jan 9, 2006 | 06:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome cwalsh540, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 9, 2006 | 06:12 AM
jowilker's Avatar
jowilker
You could use the E4OD, but the E stands for electronic, and has to be controlled by a puter.
I would suggest an AOD that does not require computer control. If your 66 is like mine there isn't a puter in there anywhere to run one.
John
Old Jan 9, 2006 | 06:13 AM
ford390gashog
good point john.
Old Jan 9, 2006 | 09:57 AM
garbz2's Avatar
garbz2
Any mid eighites AOD from a small block will bolt up to the 300. just make sure the correct flywheel and torque converter from a AOD 4.9/300 is used. not the 50 OZ balance small block unit.
Use a Lokar Cable to set up the TV valve. as there is no other way to hook up to the carb on a 300. TV cable is critical as if it is not correct it will lunch the transmission in short order. BTDT.
Garbz
Old Jan 9, 2006 | 11:13 AM
PROSTOCK's Avatar
PROSTOCK
Not that I suggest any differant than the E4OD, but you can use a newer 'puter controlled tranny. There is a kit to allow using the newer trannys in older non-'puter controlled applications, not exactly cheap, but.... go here-> http://www.becontrols.com/products/tcs.htm
