Sponsored by: Real Truck
Turn Signal controller location???
Old Jan 9, 2006 | 05:19 AM
Dave S's Avatar
Dave S
Question Turn Signal controller location???
If anyone can point out a location for me... '01 SD/CC, 5 speed...
Blinker stops working when the brakes are on... My thoughts are the controller pot for the blinkers might be going south. I pulled the dash panel down, but cannot locate anything even close, nor is it covered in the manual, and I couldn't find it in my Chilton's.
Thanks,
Dave
Old Jan 10, 2006 | 07:00 PM
Dave S's Avatar
Dave S
bump to top
Old Jan 10, 2006 | 07:33 PM
frdtruckman's Avatar
frdtruckman
the flasher / relay is kinda located behind the radio , you'll need the two u-shaped tools which are cheap and available at a parts store to remove your radio . insert the tools on each side of radio in the small holes and pull the radio out . the relay is located on the left towards steering wheel under a black cover , hard to see , might need a flashlight
Old Jan 10, 2006 | 07:50 PM
99f350sd's Avatar
99f350sd
Most likely the Multi function sw if the blinkers blink at all. Check the 4 ways.
