77 to 78/79 Grille Swap
I have a 77 F350 and want to change the grille over to the 78/79 shell. I checked the numbers and it appears the core support is the same from 77 to 79??? It also shows the head light buckets (round) for 77 and 78 are the same, but I'm not sure that is correct. The bottom of the 77 grille (where the head lights are) appears to be further from the core support, so I'd think the 77 buckets are deeper.
I can get the head light buckets for either the 78 or 79, but I would rather not have to change the core support. Has anyone done this?? Any ideas??
Thanks, John
Thanks, John
I put a '79 grill in my '73 and used the '73 radiator support. Just get the surround, headlight buckets, blinkers, and the small corner brackets with 'ears' that hold the upper corners of the grill surround. I had to drill new holes for the bottom of the headlight buckets, otherwise it's a bolt-in swap.
Marty
Marty
Originally Posted by MBBFord
You don't have to change the location of the head lights, but you do need to get the square(rectangle)brackets from a 78 79. The only thing that changes is the location of the turn signals, but all you have to do is bring down the wiring.
