Sponsored by: Real Truck
underdash plug ??
Old Jan 8, 2006 | 02:30 PM
n0tst0ck's Avatar
n0tst0ck
underdash plug ??
2002 F-250 with 5.4 engine. i am contemplating adding a prodigy brake controller sometime soon. today i was cleaning the inside and noticed a plug mounted to the lower portion of the dash just above and to the right of the gas pedal. is this where i would connect to ?? if not what is that plug for ??
Old Jan 8, 2006 | 02:37 PM
EnviroCon's Avatar
EnviroCon
I believe you're referring to the OBDII plug. The one used to download diagnostic information from the truck.
Old Jan 8, 2006 | 04:11 PM
toddyw's Avatar
toddyw
The plug you are looking for is behind the fuse cover located under the steering wheel. Remove this cover and located in the extreme upper right hand corner of the open area, will be a female plug, this connects the brake controller to your Ford prewired trailer braking system and tail light system. I just install a brake controller in my truck last month. You will need to purchase an adapter to this plug to the controller, if one is not provided, mine was in the glove box.
Old Jan 21, 2006 | 07:44 PM
n0tst0ck's Avatar
n0tst0ck
well i have just finished dismantling the entire dash face and looking at all the wiring. i see no plug for the brake controller anywhere. i do have the plug and wiring at the rear bumper. helllppp.....where is that sucker ??
Old Jan 21, 2006 | 08:25 PM
rmilchman's Avatar
rmilchman
On my '02 it was not behind the fuse cover. Remove the dash panel under the steering wheel and look all the way to the right. You should see the plug, if memory serves me correctly it's attached to the support beam. If you can not find it I can send you a picture of mine.
Old Jan 21, 2006 | 09:01 PM
EnviroCon's Avatar
EnviroCon
That sounds like where it is on my '04. Like toddyw, the matching plug w/wire's, along with the instructions for using it, were in a plastic bag in the glovebox when I bought my truck.
Old Jan 21, 2006 | 09:05 PM
rjmay's Avatar
rjmay
I am hooking up a back up video camera.
Which color wire to the brake controller is reverese?
Old Jan 22, 2006 | 12:03 AM
jello's Avatar
jello
No reverse wire on brake control harness
