electrical problems
Old Jan 8, 2006 | 11:16 AM
propguy's Avatar
propguy
Exclamation electrical problems
my 88 f-250 has been eating up my starter silonoids about every 2-6 weeks and its bugging me. no matter if i buy cheap or premium they still fail. Does anyone know what the heck is wrone with my truck?
Old Jan 8, 2006 | 11:58 AM
chrono4's Avatar
chrono4
how do they fail? i would say check voltage at the lead from the ignition while someone holds the key on the start positon, if its low, that that could cause excessive amperage draw, and heat it up alot.
Old Jan 8, 2006 | 12:16 PM
propguy's Avatar
propguy
they just die unexpectedly its a voltage drop from what i can tell
Old Jan 8, 2006 | 12:18 PM
MemOrex's Avatar
MemOrex
Do they just "click" when tryint to start? If so, i had a similar problem. I went through 2 solenoids just to find out it was the starter that was bad.
Old Jan 8, 2006 | 12:38 PM
Bob Ayers's Avatar
Bob Ayers
DC is used across the coil, not AC. So, it will not draw more current with a low voltage, the current will be lower.
If the contacts are burning up, then I would agree with the previous post, it's probably a bad starter.
