Can't get Timing Light reading
Old Oct 16, 2001 | 11:40 AM
MikeAntoniak's Avatar
MikeAntoniak
3rd Gear
Anyone ever run into a problem like this
Can't get a reading on a timing light to adjust timing on my 1973 Ford truck. 240 straight six engine.
New timing light works well on other cars. Even tried powering light from other car battery, using plug wires that gave me readings on other cars.
Truck started running rough, losing power while driving and idling very rough. Checked carb, points, top dead center on #1 plug, then thought maybe adjustment by a timing light would get it right.
Any ideas why I can't get a timing light reading, or the logical progression of where to look from here?
Thanks.
Mike
Old Oct 16, 2001 | 01:31 PM
tetraruby's Avatar
tetraruby
Maybe you're not getting a signal to cylinder #1. I'd try #2,3,4,5,6 just to verify a working gun and setup (not to set the timing).
Old Oct 16, 2001 | 01:48 PM
mtraum's Avatar
mtraum
could be bad wire on #1 cylender, or bad distributor cap.
Old Oct 16, 2001 | 02:25 PM
MikeAntoniak
3rd Gear
tried all the wires, even coil wire but no light, although it works fine with other vehicles.
Thanks
Old Oct 16, 2001 | 04:43 PM
tetraruby's Avatar
tetraruby
Probably poor induction through the wires' insulation then (since it does run).
Old Oct 16, 2001 | 08:16 PM
BB's Avatar
BB
adephue
21
Aug 30, 2014 03:02 PM
paintballkaos
Escape & Escape Hybrid
Nov 24, 2012 07:58 AM
Bigbirdshotyou
1983 - 2012 Ranger & B-Series
Sep 5, 2012 09:05 AM
xFordGurl
Aug 31, 2012 02:19 PM
MDSuperDuty
Feb 15, 2011 07:26 PM
