Sponsored by: Real Truck
Front end clunk
Old Jan 7, 2006 | 09:15 PM
John Kiernan's Avatar
John Kiernan
Front end clunk
After I lock my hubs and put my truck in 4WD I get a clunking sound when making sharp turns in like a parking lot for example. It happens after I disengage the hubs and put the truck back to 2WD. Dealer says of course they can't hear anything. What is this ?
Old Jan 7, 2006 | 09:57 PM
Hayapower!'s Avatar
Hayapower!
Manual T case/hubs or ESOF.. Auto lock..
If ESOF, sometimes you'll need to engage/dis the tranfer case a few times followed up with a series of backups to ensure disengagement of the auto hubs.. EVERY time I use 4x4 I 'manually' check for hub release by reaching under the truck and giving the axle/u joint a slight rotation.. Mine was at the shop for some warranty work and they happened to lock mine (T case) and it never released until I happened to notice it in a parking area making hard turn/s many days later.. Kind of a problem of the beast for some at times.. Manual Tcase/hubs shouldn't be an issue as far as unlocking...
................HP............
Old Jan 8, 2006 | 09:20 AM
John Kiernan
I have the manual front hubs with the selector switch inside the cab 2WD, 4WD, 4 Low.
Old Jan 8, 2006 | 09:54 AM
RushN350's Avatar
RushN350
It's the front u-joints binding, Even with manual hubs you should unlock them then back-up 10-15 feet or so maybe even a couple times to get them to dis-engage. Sometimes they with unlock right away but somtimes not.
