Too Much Carb?
Old Jan 7, 2006 | 05:06 PM
pntrbl's Avatar
pntrbl
Too Much Carb?
I've got a 65 F250 with a standard 2bbl 352 that's needin' some repairing.
The 2 bbl's leaking at the pump diaphragm which ain't a big job, but the intake manifold is also leaking oil at the rear of the block and that's one heavy sob!
An aluminum Edelbrock is an obvious choice but here's the thing on a carb, I've already got a 750 Holley. New in the box. $100. Vacuum secondary with a mechanical choke.
That'd be fine on that 410" stroker motor I'd like to build someday but whadddaya guys think on a plain ol' 352? Too much carb?
Old Jan 7, 2006 | 05:09 PM
ford390gashog's Avatar
ford390gashog
waaaaaaaay to much carb even for a 410 stroker. that would swamp the 352.
Old Jan 7, 2006 | 05:13 PM
jd_sylvia's Avatar
jd_sylvia
I have a 600 CFM Holley vacuum secondary on my 352 that seems to be plenty of carb because it has plenty of get up and go and gets great gas mileage.
jd
Old Jan 7, 2006 | 07:47 PM
Scouder's Avatar
Scouder
I'm not buying the "too much carb" thing. I say run it. The world is full of 350 Chevs running 750's every day. I certainly wouldn't buy another carb if you already have the 750.
-Scouder
Old Jan 7, 2006 | 08:00 PM
ceetwarrior's Avatar
ceetwarrior
I'm with Scouder, I'd say run it since you already have it. But if it swamps it, then you can always jet it way down etc...
Old Jan 7, 2006 | 08:47 PM
rusty70f100's Avatar
rusty70f100
I do agree that it's probably too much carb, but you have it so give it a shot. Throw it on there and run it. It'll probably work fine. The vacuum secondaries will "size" the carb to the engine, so the thing will probably never get the opportunity to flow the full 750cfm, though.
Old Jan 7, 2006 | 10:07 PM
Chevy_Eater's Avatar
Chevy_Eater
I just got my 600CFM H*lley, here's a chart it has on the side of the box:
(For vacuum secondary carbs)
-----------------Engine Type---------------
----------------Mild Hot Wild----------------
Engine Size
300------ 390CFM 600CFM 650CFM
350------ 600CFM 650CFM 750CFM
400------ 650CFM 750CFM 750CFM
450------ 750CFM 750CFM 850CFM
500------ 750CFM 850CFM 950CFM
550------ 850CFM 950CFM 950CFM
Old Jan 7, 2006 | 10:45 PM
seetwisted's Avatar
seetwisted
Exclamation small block big block carb size...
some deep into the night surfing for power reading has brought me to this,unless you have a highly unusual fe a 750 carb will be way too much. A 600 to 650 or so is better, use it for trading material for what you need.It's not just the jets and such but the size of the carb also gives the correct vacuum ...when the carb gets too big you loose vacuum , you get less efficient mixture from lower volocities and less throttle response. some big time engine builders use a formula for the vacuum and volume at given rpm's.Also,as strange as it sounds a chevy 350...small block...can use a higher cfm carb than a big block because of the difference in runner length and volume in manifold design and the demand on available mixture from the manifold every time a cylinder calls for it.Check out HTTP://www.victorylibrary.com/mopar/intake-tech-c.htm
Old Jan 7, 2006 | 10:48 PM
Putt's Avatar
Putt
The 750 cfm will work fine since you already have it. I would get some smaller jets to fine tune it to the 352, but aside from that it will work as is.
Remember the cfm of the carb does NOT make it run richer only total potential airflow; the jets, secondary metering plate and power valve control the air/fuel mixture.
Old Jan 7, 2006 | 11:33 PM
rusty70f100
Something interesting to note here:
Holley 500cfm 2 barrel throttle bore diameter - 1 11/16"
Holley 750cfm 4 barrel throttle bore diameter - 1 11/16"
I dont think we would be complaining too much if he was putting a 500cfm 2 barrel on it. This 750 also has vacuum secondaries, so if the engine doesn't need the extra air, it doesn't get it. It's not like he's got a double-pumper. So what's the big deal here?
Old Jan 7, 2006 | 11:37 PM
ceetwarrior
Yep Rusty's right, and if there is a prob then rejet like you normally would with most carbs. Vaccum secs is the key here.
Old Jan 7, 2006 | 11:54 PM
fordeverpower's Avatar
fordeverpower
i too would use it, it may be useful down the road if any future mods are done.
Old Jan 8, 2006 | 09:12 AM
pntrbl's Avatar
pntrbl
Wow! Great discussion and Thank You one and all for the responses.
Based on the "I already have it" principle I'm gonna give it a shot. I've raced 2 bbl Holleys and still got the jet kit, power valves, squirters, etc. A vacuum secondary is a new deal for me but I hear there's a spring in there somewhere that controls the opening. I'll find it.
So that leads me to the next question, bearing in mind I'm not looking for high rpm work but would like to build a solid 390 or 410 with a cam and headers some day, what kinda manifold? Single plane? Dual? Aluminum Edelbrock I suppose. Maybe a decent cast iron outa the junkyard?
Old Jan 8, 2006 | 09:47 AM
seetwisted's Avatar
seetwisted
I guess I got excited about something I read,and Rusty70f100 makes a valid point and I don't know that much about Holleys. Now in moderation I have more to think about...and about the manifold...I ran a Holly street dominator for a while and flat out on the freeway it was amazing (single plane) but I felt I could do better on lower end.I found an Offenhauser dual port in a guys backyard and currently running it.So from experience the stock 4v was a step up and ran good,the Holley was crazy good on top and the Offey is strong on bottom and mid and feels like a kick in the pants when the secondaries open.But I think it lacks a little on the very top (around a 100 and up)...
Old Jan 8, 2006 | 11:03 AM
Scouder's Avatar
Scouder
For your application it would be hard to beat a Performer RPM. It won't kill your bottom, but will allow some airflow for future mods. Factory 4bbl manifolds work OK, but you just about gotta have somebody help set it on the engine.
-Scouder
