Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Gas Filter Hoses
Old Jan 7, 2006 | 04:56 PM
tonyford's Avatar
tonyford
Gas Filter Hoses
The hose going to the engine from the gas filter looks easy to take off the filter, a little white clip that pushes through when you spread the tangs apart, but the opposite end, the hose coming from the tank looks different. You need a special tool for this side?
I had a different set up on my Ford Ranger, I had this tool that would push on a clamp that would release the hose from the filter.
Any help appreciated, thanks..
Old Jan 7, 2006 | 05:13 PM
ford390gashog's Avatar
ford390gashog
you need a ford fuel filter tool. they run 5-9.00 at any parts store the metal ones are best.
Old Jan 7, 2006 | 05:42 PM
tonyford's Avatar
tonyford
Thank you, that is what I thought. Like I said, the one side will come off easy, the side from the tank is where you need the tool...
Old Jan 8, 2006 | 01:39 PM
tonyford's Avatar
tonyford
I posted this on another thread concerning the fuel filter:
Now the gas filter is another story. That takes a bit of doing. A small screwdriver, pliers, those miniature needle nose pliers, and lots of patience. The clip that holds the hose on that comes from the tank (the one towards the front of the engine) is pretty easy to get off, they give you new clips with the new filter, so you can break off the tabs on the old clip on THIS SIDE ONLY and it comes off easily. The other side is different and the clip does NOT come off completely to remove the hose from the filter. You need determination and the tools mentioned above, the tabs of this clip are facing upward and hard to see and get to. With a small pair of pliers you can twist the connection gently toward you, with a small screwdriver push the white prong from the nearest side inward and down, once one side is released the other side comes off pretty easy. DO NOT try and remove this clip, it stays on the connection, just push it down as far as it will go and pull off the hose. Have plenty of rags on hand and something to catch the gas as it drains out. Again this will be simple the next time it has to be done. The tool they gave me at the auto parts store does NOT apply this model Ford fuel filter, even though it says on it 1990 to current models. There may be a tool out there, but can't see how anything would make it easier to take that one clip off.
sdetweil
Dec 3, 2011 09:24 AM
onug
Modular V10 (6.8l)
Sep 9, 2011 10:08 PM
Lil Josh
19
Nov 15, 2008 09:20 AM
captchas
Modular V10 (6.8l)
20
May 7, 2006 05:55 PM
RDMoore
Aerostar
Apr 6, 2003 10:51 PM
