Sponsored by: Real Truck
Headliner removal
Old Jan 7, 2006 | 09:01 AM
billbain's Avatar
billbain
Headliner removal
How is the headliner removed on the superduty, any tips or tricks, thanks!
Old Jan 7, 2006 | 09:11 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Bill, got to remove everything as far as grab handles, visors, overhead console etc. I removed the plastic pillar covers just to make things easier. If I also remember correctly you need to turn it 90 degrees and go out thru the front door if its the 4 door. pretty easy job it held up there with little metal clips at the windshield just pulled easily and it came right out.
Old Jan 7, 2006 | 11:49 AM
Racerguy's Avatar
Racerguy
On a crew cab it wont fit through any of the doors without kinking it.
The shop manual says you have to remove the rear window and slide it out the back.
Old Jan 7, 2006 | 12:02 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
racerguy, I have an 03 crew cab and I got mine out thru the drivers door without kinking it??? What a PITA it could turn into if you had to pull the back window!!
Old Jan 7, 2006 | 12:12 PM
Racerguy's Avatar
Racerguy
I tried a couple months ago going through each door, even took the seats out. No way could I get it without kinking the headliner. I didn't want to do that so I sent it to our bodyshop and they did it through the back window.
