Offroad & 4x4
need some advice
Old Jan 6, 2006 | 08:12 PM
timberwolf-man's Avatar
timberwolf-man
Question need some advice
i have a 81 f150 2wd swb and im looking for a 4x4 frame to put the 2wd body on. i was thinking a 79 frame with a solid front axle.#1 what frame do yall think is the best? #2 what all frames match my cab mounts (what all frames can i put my 81 body on)? #3 could i get a 79 f250 single cab long wheel base and cut the frame to be short wheel base ?? any advice will be appreciated
Old Jan 6, 2006 | 08:55 PM
Franken-Truck's Avatar
Franken-Truck
Body mounts that will match are the 80-97 truck frames. Solid axle options are 85.5-97 F-350 4x4 trucks.
Of course, with a moderate amount of fabrication skill, you can stick just about any body on any frame you want
Yes you can cut the frame short, and move the axle forward. Quite a few people have done this.
I would think a mid 70's High-Boy frame would be best if your looking to cut and shorten. There straight as an arrow down the frame rails all the way back, were the 77.5+ frames widen from just about right behind the cab to in front of the springs.
Old Jan 7, 2006 | 12:07 AM
fishmanndotcom's Avatar
fishmanndotcom
there is no difference b/t the 2wd and 4wed frames. just get a t-case and front axle and you have 4x4
-cutts-
Old Jan 7, 2006 | 01:37 PM
timberwolf-man
how hard would it be to move the rear axle forward??
Old Jan 7, 2006 | 01:51 PM
monsterbaby's Avatar
monsterbaby
-cutts-
isn't the 81 frames the swiss cheese units or am I thinking wrong.
Old Jan 7, 2006 | 04:39 PM
timberwolf-man
yea some of them are. i saw a post on that and they said for it to be a cheese frame u had to have big holes in the frame. mine has holes in it but they a small holes so i dont think mine is. i hope not
