Sponsored by: Auxito
lightning blowers
Old Jan 6, 2006 | 03:13 PM
The old ford guy's Avatar
The old ford guy
lightning blowers
Hi Folks. Has anyone ever taken a lightning blower assembly and put it on a none lightning eng.example I have a 2002 5.4 triton and a fellow on ebay has a complete blower setup.I always thought that you would have to change computers and install a hiflow pump. Any info would be great!!!!!!!!!!
Last edited by The old ford guy; Jan 6, 2006 at 03:15 PM. Reason: fingers to big for keyboard hit wrong buttons
Old Jan 6, 2006 | 07:13 PM
kspilkinton's Avatar
kspilkinton
I've not done it and only briefly looked into it. From my research, the fuel pump, ECU program, and whole intake setup would need to change. I also think the injectors would need a change. The Lightning also uses a forged crank and pistons... if you don't, it'd be a really good idea.
-Kerry
Old Jan 8, 2006 | 10:28 PM
The old ford guy
Lightning blower
My truck is a 2002 f151 e/c Stage 2 Jack Roush Edition,The truck had an option of a vortex blower setup. My truck did not have this option and I have looked into pricing out the vortex and it was almost 5500.00.So I checked on ebay and I fellow had a complete setup Intake manifold ,injectors ect. and only 1600.00us.A little bit more resonable,but not a true roush setup,but what the hey. boost is boost. My truck has only 7200 kilos(4800 miles) So I really don't want to pull the engie out and start a rebuild. Thanks Rick
Old Jan 9, 2006 | 08:24 AM
eveready77's Avatar
eveready77
Old ford guy, I was told that non lightning/Harley 5.4's have a lower compression ratio than their blower fed brothers. Does anyone know if this is true? That would also be a consideration before supercharging A n/a 5.4.I am also looking at supercharging my 5.4 with the lightning kit and was told that the higher compression ratio would not work.
Old Jan 9, 2006 | 07:05 PM
kspilkinton
I believe the '99 and up Lightning has a 8.0:1 compression ratio, where the '99 NA 5.4 F150s have 8.8:1...
The reason for the lower compression in a supercharged motoris to give you the ability to boost the charge more, making more horsepower.
If you look up supercharger technology or tech on a search engine, you'll find how each works and which is best for your application. IMO and from what I've read a centrigual charger is best unless you plan on upgrading the engine internals.
-Kerry
Old Jan 9, 2006 | 07:13 PM
eveready77's Avatar
eveready77
Kerry, with that much diffrence in compression, would a lightning setup tear up the n/a engine? How is the centrifigul charger safer?
Old Jan 9, 2006 | 08:00 PM
kspilkinton
From what I've read, a stock engine should only see, at most, 6 psi of boost. There's something about the designs, but the centrifugal produces it's pressure in the head. The roots and the screw (iirc) produce it outside so you have more of a chance of getting a higher boost than the engine would like... boom. That search I listed will give you way more technicalities than I can recall... that's your best bet.
By the way, I think the Lightning superchargers are screw types. That's why Ford went with lower compression in the Lightning.
-Kerry
Old Jan 9, 2006 | 08:30 PM
eveready77's Avatar
eveready77
That makes sense, and sounds about right......If there is something i'd like to do, it'll tear up my truck!!! LOL! Thanks for the info.
fbodyfan
1997 - 2003 F150
Mar 22, 2006 07:24 PM
hc130flyboy
Apr 25, 2005 08:16 PM
hc130flyboy
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 24, 2005 07:28 AM
99roush
Jun 26, 2004 08:08 PM
