New MEMBER---> New Problem
Old Jan 6, 2006 | 08:39 AM
7 VII 7's Avatar
7 VII 7
Exclamation New MEMBER---> New Problem
Hey guys how are ya'll doing today?
well I am a new member and I am asking a question based on my GF's 1999 4WD Ford Explorer.
in March of 2002 my gf got a factory FORD alarm system installed in car. the battery died and was we installed a new one 2 days ago. Well now we are having a problem with her factory alarm system that was installed a year after she got the car. I called FORD and they said the alarm has to be de-activated or turned of. How do I do this? They said there is a switch on the alarm system box under the dash *near her feet* All I saw was a little white round switch that you turn. I turned it and the little red light on the box turned off. yet it would not start!
what should I do.. we need to fix this as soon as possible it is stranded at her work
PLEASE HELP!!
- Dave God Bless
Old Jan 6, 2006 | 09:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 6, 2006 | 10:46 AM
7 VII 7's Avatar
7 VII 7
hey guys can you please help!
Old Jan 6, 2006 | 08:35 PM
black wolf's Avatar
black wolf
PLEASE HELP!!
- Dave God Bless
Sorry to here that. if you can disconnect the alarm maybe it will start for you..im not so sure but i never had that kind of problem but its worth a try. good luck
Old Jan 6, 2006 | 08:37 PM
black wolf's Avatar
black wolf
By the way welcome to the FTE 7 VII 7
Old Jan 7, 2006 | 12:51 PM
Rick55's Avatar
Rick55
Hey,
I'm not familiar with your alarm system...could that switch have been an ignition kill switch? Maybe you can switch it back to the original position & start the vehicle?
Do you have an instruction manual for the alarm? If not, maybe you can call the dealer & they can assist.
Old Jan 9, 2006 | 08:38 AM
7 VII 7's Avatar
7 VII 7
well no such luck we are getting a company to come out and dis-arm the alarm for $150. it sucks neither of us have a lot of money but it has to be done
Old Jan 10, 2006 | 08:24 AM
7 VII 7's Avatar
7 VII 7
still not workin
well if I uplug the alarm which is connected to the starter... will the car still start?
please help!
Old Jan 10, 2006 | 02:42 PM
7 VII 7's Avatar
7 VII 7
anyone?
bump bump bump
Old Jan 11, 2006 | 09:04 AM
7 VII 7's Avatar
7 VII 7
come on guys please give me something.
Old Jan 11, 2006 | 12:54 PM
z28dug's Avatar
z28dug
What makes you so sure it is the alarm system? When you say doesn't start, does that mean doesn't crank or cranks but won't fire?
I think everyone needs a little more details on the problem.
What happened with the company that was going to come out and disable the alarm?
Old Jan 11, 2006 | 01:08 PM
7 VII 7's Avatar
7 VII 7
alarm
well we changed the battery and everything worked well... BUT!! when you stuck the key in the ignition to start the car it would not work... you flip the key over and insert it again and it would start.... she drove it for a day and then it died on her outside her work. The red "THEFT" light keeps blinking in her dash when she tries to start it.
Thats why we think its the alarm?
any ideas?
Old Jan 11, 2006 | 01:56 PM
z28dug's Avatar
z28dug
When you say it died on her at work. Define died. Was she driving and it died and would not start or was it OK when she got to work but wouldn't start when she came out from work.
A rapidly flashing theft light, or PATS light, usually indicates a problem with the keys or the PATS transponder...happended to my 2003...fortunately mine was under warranty.
Does she have another key? That's the first thing I would try.
If that doesn't work I would then disconnect the battery for 15 minutes so everything resets. If that doesn't work the next thing I would do would be to turn on the key and try to jump the solenoid. If that fails I'm calling AAA to tow it to the dealer to diagnose the problem.
Old Jan 12, 2006 | 08:26 AM
7 VII 7's Avatar
7 VII 7
Keys
She parked it.. turned it off.. worked for 12 hours and then came out and it did not start.
Well we had someone from the alarm store come out. He said that the FORD key is not letting the car start because it he says that the car thinks its the wrong key. He suggested calling FORD dealerhship... GIVING THE VIN number, the MODEL and everything to get a NEW KEY for that car for $100. He was out side her work leaving the key in the car for 10mins waiting for that THEFT light to stop blinking. Is he on the right path?
what the deal? Should I try to disconnect the battery before spending $100 on a key?
Old Jan 12, 2006 | 11:02 AM
z28dug's Avatar
z28dug
You may be on the right track. I would still disconnect the battery first and let everything reset itself to see if that takes care of the problem.
Before you get a new key from Ford...check with your local locksmiths...they are usually a lot lower than Ford in price.
Doesn't your girlfriend have a 2nd key?
