3.0L V6 Identification
Old 01-05-2006, 09:14 PM
propellerhead's Avatar
propellerhead
propellerhead is offline
Is there some sort of 3.0L V6 identification guide? My son's 96 Ranger had an engine replaced but I wasn't able to find out what the donor engine was from. Would the engine serial number have that encoded? Where do I find the serial number? If I post a few pics of the engine, can you guys maybe narrow it down? I need an idler pulley for it but I can't just ask for an idler pulley for a 96 Ranger anymore.
Thanks.
Old 01-08-2006, 06:41 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
8th digit of the VIN is the engine code. Some more info relevant to the 3.0L can be found HERE.
Old 01-08-2006, 06:49 PM
propellerhead
Well, the VIN of the truck doesn't mean much when the engine has been replaced. The problem is I don't know which 3.0L V6 is in it now. Aerostar, Probe, Ranger, Taurus, Tempo, Mazda B3000, Mercury Sable, Topaz... I don't know. Nor do I know what year the engine came from.
Old 01-08-2006, 07:02 PM
Rockledge's Avatar
Rockledge
Good point.
FWIW, there is supposed to be a "Ford Broadcast Code" sticker that is used by engine rebuilders to determine the exact engine and application ID. It is a paper sticker usually located on the cam/rocker/valve cover and/or the front cover. The stickers are often marred up real good or gone completely, but it's worth a look.
If you get the code you might be able to call a dealer or rebuild shop and have them tell you what application the code points to.
Old 01-08-2006, 07:17 PM
propellerhead
There's a sticker that's still legible. I'll write it down and ask a Ford tech. I think that's my best option now. Thanks!
Old 02-22-2018, 06:02 PM
Yohna1's Avatar
Yohna1
Yohna1 is offline
Exclamation V6 3.0 engine help
Were you able to find out the specs on the replaced engine? I'm having the same issue. I found a barcode sticker on the left side of the engine. It's barely readable but i'm not sure if that's the right one.
mnewbolds
03-12-2016 10:59 AM
dclarkson
1983 - 2012 Ranger & B-Series
12-24-2011 08:20 PM
RickBraden
12-08-2010 06:17 PM
ticorover
10-04-2010 07:46 PM
Quick Reply: 3.0L V6 Identification
