Problems with AOD or Kickdown..
Old Jan 5, 2006 | 02:25 PM
Jrog86's Avatar
Jrog86
I have an '86 150 4x2 with a 302 EFI. Today I was driving home from work, and It's hard for my tranny to switch into overdrive when around or over 55 mph. I have to let off of the pedal for it to switch. But today on the inerstate, I was driving about 70mph and then it started to get a little slower, and anytime that I pushed just a little on the gas, it would kickdown to a lower gear. When doing this, it was harder to maintain speed and then some smoke came out. Then I slowed to about 55mph because there, the smoke was gone, and was a smooth ride. But at the high speed, it didn't like. I'm confused on this one...
Old Jan 6, 2006 | 02:04 PM
Jrog86's Avatar
Jrog86
can anybody help me out with this??
I was just doing this to get it back on the front page.
Old Jan 6, 2006 | 02:05 PM
Casey's Avatar
Casey
It sounds like the TV linkage is not adjusted correctly. It needs to be EXACTLY correct or the trans won't work right. Sorry, but I don't have a copy of the procedure to adjust it.
Old Jan 6, 2006 | 09:19 PM
Jrog86's Avatar
Jrog86
the motor is out of a '91 Crown vic. same block, using same truck intakes and the truck throttle body and cables. I'll check that out. Thanks. Let you know how it goes.
