1978 - 1996 Big Bronco
Cold Ride Home
Old Jan 5, 2006 | 11:27 AM
Schlump's Avatar
Schlump
Cold Ride Home
After returning from Texas (+70 degrees) to Saskatchewan (0 degrees) in the middle of the night. I rolled the rear window down and dropped the tailgate to load the luggage. After doing this I could not get the tailgate latched again. I played with the latches and finally got it to at least hold shut. The right side (passenger) however definately was not latching properly. I stopped and got some gas line antifreeze and poured it over the latches thinking that they had frozen but had little luck. Needless to say the +70 mile ride home was more than a little cold with the back window down on top of the typical poor Bronco heat!
If I remember properly the safety switch for the rear glass is on the left side (drivers) isn't it? I can press the latches together and get them to hold shut and then pull the handle to release them, so the internal latching mechanism should be working. I see no signs of the passenger side latching pin having moved. Any other ideas?
Old Jan 5, 2006 | 03:10 PM
poffutt's Avatar
poffutt
Move to Texas, I live in Houston. I have been really enjoying this 70-80 degrees weather and I still have my whole top off.
Sorry not try to rub it in.
