42" SWAMPERS
I Know this thing is really stuffing them. They will rub if I flex even a little
I hate bushwackers
I am not afraid of cutting and rolling the fenders, and I dont want to add much more lift
I think the D60 swap in front is wider so it should get the tires off the radius arms(offset rims too)
clearance in the rear wont be a problem since I'm making a tubing stepside of sorts soon
these 42's are borrowed anyway I'm just using them to help me make the decision on tire size so far nothing is permanent but it does look good
I took pics when i came home but it's dark and raining so they kinda suck
besides Ive never posted pics so let me figure that out and I'll post them soon
thanks
I hate bushwackers
thanks
I know you said you hate Bushwackers but I've got to tell you that IF you have low backspacing on those 42's to stick them out a bit more the Bushwacker flares would look killer with them, plus the backspacing will put them out far enough so they wouldn't rub your radius arms. The reason that those flares often look goofy is because they stick way out and people use tires that don't fill them out.
check out my gallery...im running 44's with 6 inches and a good bit of fender and a little grill trimming, i had to move the axle foward to keep the tires from rubbing the body mounts, but now its perfect...the suspension bottoms out just before the tires hit the fenders, and i can turn the wheels lock to lock at full stuff no problem...so it cna be done
