Which oil?
I've been running 20W50, I had it recommended due to the higher temps and to improve the oil pressure. Actually the oil pressure problem was bogus, just the sensor. But it seemed to run quieter.
It's winter now though that seems to mean 70F this year. I'm about to change the oil, which oil would be best?
Granted, I'm no expert on oils and you might get a better answer in the Oil & Lubrication forum, but I've read recently that the maximum viscosity spread you want in an oil is no more than 30, so the the old 20W50 is right at the limit. Perhaps it would be better to switch to an oil that brings those numbers closer together.
Anybody who knows more about this than I care to elaborate?
Short answer, stick with 10w30, unless you have a very tired engine. The closer the two numbers are, the better. 20w50 is pretty thick stuff, your bearings have to be pretty close to shot to actually need oil that thick.
80w90 is the right oil for the diffs.
