Offroad & 4x4
Trac Bar
Old Jan 5, 2006 | 12:06 AM
OffRoadF-150's Avatar
OffRoadF-150
Trac Bar
How does the trac bar mount to the frame while doing an SAS? What trac bar should i buy for this type of application?
Thanks,
Will
Old Jan 5, 2006 | 01:09 AM
mustange70's Avatar
mustange70
what kind of truck? As i could snap a picture if you want.
Old Jan 5, 2006 | 04:35 AM
kev150's Avatar
kev150
pic of my sas
Heres a pic of the SAS I did on my 92 f150, the trac bar wasnt done at the time, it still needed to be lengthened....
The top mount isnt as easy to see, but I had to remove a rivit from the coil bucket and drill through so I could mount the bracket and replace the rivit I removed.
Remember that your trac bar and your drag link need to be parellel
Old Jan 5, 2006 | 12:34 PM
chrono4's Avatar
chrono4
might want to fix ur pics there kev.
Old Jan 5, 2006 | 02:13 PM
kev150's Avatar
kev150
it looks ok from my computer
whats wrong with it?
Old Jan 5, 2006 | 07:52 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
i really wouldnt trust tractor heims for steering duties...unless it doesnt see the highway
that could be bad
Old Jan 6, 2006 | 02:41 AM
kev150's Avatar
kev150
They're going to replaced with stuff from bullet proof steering, but should be fine for now, thanks for the concern.
Old Jan 6, 2006 | 05:03 PM
chrono4's Avatar
chrono4
nothing now kev, musta been the other comp.
Old Jan 6, 2006 | 06:12 PM
thesprocket26's Avatar
thesprocket26
Silly question I must have forgotten, why do they need to be parallel?
Old Jan 6, 2006 | 07:27 PM
chrono4's Avatar
chrono4
so that when your suspension cycles out, you dont have lots of bumpsteer i think.
Old Jan 9, 2006 | 06:11 PM
kev150's Avatar
kev150
Yes, that would be correct
Old Jan 10, 2006 | 05:27 AM
78f3504x4's Avatar
78f3504x4
I have pics in my gallery. I used a custom 18" adjustable track bar, and mounted it from the stock location in the 78 axle to the middle of the engine crossmember after welding 1/4" thick mild steel to the crossmember. I drilled a 1/2" hole to mount the trackbar.
Old Jan 10, 2006 | 07:18 AM
1BadB2's Avatar
1BadB2
no offense intended but that looks pretty scary kev...you got a few bugs to work out there...but awesome effort..you're about 80% of the way.
and to answer the question..im going to assume it didnt come with a solid axle so you will probably want to fab up your own...and mount it to the side of ur frame...i see ur name says F150 and most F150 frame is flat right there so it will be very simple to bolt on..just make an L-shape...to wrap around the frame, then use some 2" ID tube..cut out a side, drill hole..weld to L plate and use some 1/4" flatbar to brace it to ur engine crossmember. ill snap a picture of mine when i have a chance.
Old Jan 10, 2006 | 08:01 AM
chrono4's Avatar
chrono4
how does that look scary? you obviously havent seen the scary steering page.
Old Jan 10, 2006 | 09:48 AM
DaveBowman's Avatar
DaveBowman
You should at least tie the bottom of the upper bracket in to the engine crossmember. After they are that way for a while they will crack the frame or the bracket.
