heads 240 cs 300
Old Jan 4, 2006 | 11:31 PM
Jebadiah04's Avatar
Jebadiah04
heads 240 cs 300
had a little debate tongiht, what EXACTLY is the difference between the heads on the 240 and the heads on the 300?
~tater
Old Jan 6, 2006 | 09:08 AM
77300i6's Avatar
77300i6
Combustion Chamber size is smaller on the 240. That's why you increase CR when putting it on a 300. The valves may be smaller, but I'm not sure on that one.
Old Jan 29, 2006 | 12:24 AM
ProjectNut's Avatar
ProjectNut
So, if the combustion chanber on the 300 head is larger than the one on the 240, putting a 300 head on a 240 block will lower the CR? My '66 has the 240 with a VERY sick head-cracked in two places and badly worn valve seats and guides thanks to unleaded gas and 300k miles. I've got a 300 out of a '76 with a nearly perfect head, but everything else needs to be rebuilt. I'd like to put the head on the 240 until I can rebuild the 300 (budget delays) since I need the truck running. I have to run 91 octane (california gas sucks) in order to keep it running as it is. Lowering the CR should mean I can run a lower octane, right? I'd have to check the new CR of course, but I know where to look to find that procedure although I haven't done it in, gad, nearly 20 years.
Old Jan 29, 2006 | 01:24 AM
Jebadiah04's Avatar
Jebadiah04
that is correct, but i dont think a 240 head has enough compression to make you have to run high octane but your right, lower compression should make it run on lower octane fuel, one thing you may wanna check if your pinging, is your timing.
Old Jan 29, 2006 | 11:39 AM
ProjectNut's Avatar
ProjectNut
I don't have a pinging problem (that I can hear, anyway) but the truck suuuuure doean't like 87 octane. The performance drops noticeably, and it's a lot hard to start. After I put the 300 head on, I'll certainly keep my ears open and play with the timing to get the best performance out of the old guy.
