im getting my 03 ranger fx4 tomrrow..or friday...just have a couple of questions..what size rims come on these trucks?? what it the biggest tire on can fit on here with a stock suspension??
on my 2000 i've got 16's and the biggest tire that i had was a 295 75 16 with only a minor rub when fulling turning left. it is a 4wd and is now lifted but was at stock ride height with those monsterous tires!
is it a level II? in 03 ford had the fx4 and the fx4 level II. the fx4 comes stock with 245 tires and 16 inch wheels. the level II comes with the manual transfer case with the stick, and 31 inch tires with 15 inch forged alcoa rims. the big difference between the two trucks is the level II is the only one that comes with the torson differential. the biggest tires i have seen on stock rangers are 33 inch.
what do you have for a lift?
and are the same size tires still on there?
im gonna go 3" body with 33's
i've got the same set up your talking about. the tire dia. is 33" but i've got 285 75 16 now but would like to go back to the 295 75 16, fills up the well a little more!
