Offroad & 4x4
swap or not
Old Jan 4, 2006 | 07:20 PM
dm_lucky's Avatar
dm_lucky
Cool swap or not
I have a '91 ford f-250 with a 7.5l "460" with the independent i-beam suspention. A couple weeks ago i was playing in the snow and on my way back home one of the bearing in the front end seased up and caused the tire to break free i fixed everythign changing the steering knuckle, brake caliper, outer axle ,rotor and the spindle but now my problem is that the 4wd wont engade the parts are all out of a '78 ford 3/4 ton i used the automatic locking hub out of my truck so im not sure if that may be my problem or if its something else i was also corious if it would be easier just to swap out the axle for a soild axle and if so a recommondation
Old Jan 4, 2006 | 08:57 PM
fordborn's Avatar
fordborn
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Jan 5, 2006 | 12:10 AM
ramboss429's Avatar
ramboss429
If you do the solid axle swap look for a Dana 60 front. I can't help ya out with the 4wd not engaging problem, as I have never worked on the TTB front ends before.
Old Jan 5, 2006 | 12:52 AM
mustange70's Avatar
mustange70
I would check the hub after something like that happened, as its entirely possible it got stripped out in the process.
If you afford the purchase price of a dana 60 for these trucks i'd say go for it, but you'll right around 1000 bucks for it though.
Old Jan 5, 2006 | 12:37 PM
chrono4's Avatar
chrono4
put it in 4wd, and in park, climb under there and see if the drive shaft spins. if so, somthing in the t case. if it wont, then its got to be in the hubs. the auto hubs suck, so might as well get some good manual hubs.
Old Jan 5, 2006 | 02:56 PM
fishmanndotcom's Avatar
fishmanndotcom
it's hard to say without actualy looking at the your hubs but i would also say they could easily be stripped.
Do the Dana 60 front swap. it's a bolt in, is very easy and more han worth the money. look in my gallery for a brief glimpse of the swap.
in fact i seem to know where a D60 sits right now
-cutts-
