1978 - 1996 Big Bronco
hesitation when warm mostly
Old Jan 4, 2006 | 06:21 PM
chrispaul's Avatar
chrispaul
I have a 93 ford bronco, 109,000 miles. Recent oil change, doesnt matter how much gas in tank, mostly when warm and from a stop, only in low mph situations will begin to go, then hesitate. Seems like your out of gas, then eventually after three or four tries gets up and going. NO probs on highway or high speeds. There is a loud clunking noise, sounds as if a hammer is hitting floor board. I could be imagining this but it seems the more bells and whistles going the worse it is, however if everything is off, it still happens. NO check engine light on, cleaned out Idle Air Control, plugs, wires distributor cap are good. I have heard Fuel Pressure Regulator, what else can I do????
Old Jan 4, 2006 | 06:47 PM
imlikeojnow's Avatar
imlikeojnow
check for codes. see if it is throwing any. it almost sounds like a transmission problem or throttle problem
