Power Door Locks And Windows Stopped Working
99 F-350 4x4 My Power Door Locks Stopped Working Wich Was No Big Deal But Now My Windows Have Stopped, My Window Is Stuck Down And I Do Not Want Rain Or The Big Tree Rats To Get In My Truck Can Someone Give Me Some Ideas, Also I Do Not Have A Fuse Diagram Please Help Asap. Thanks Kelsokell
My passenger doorlock is working sporadically and sometimes real slow like the battery is low or something. This seems to be the case regardless of whether I use the remote or hit the button inside the cab. Anyone have any ideas on this?
Oh, and my dome light sometimes stays on for no apparent reason.
Originally Posted by cookie88
GEM module. Mounted to the back of the fusebox in the cab. Try disconnecting the connectors to it to reset it.
Windows & power doork locks not working.
I checked all the fuses, relays, switches, all checked out good. Dash board started going crazy lights going on & off. I took truck to dealership they had just as hard of time as I had. I bought the truck used, they found a bunch of shorts and will have to rewire a bunch of wires to fix problem, also replace the door switches those were causing the door ajar light to stay on, even the air bag light was stuck on , 8 hours because some idiot cut a buunch of wires under the dash, looks like trying to install a brake controller & radio.
