'89 E350 5.8L Code questions
Old Jan 4, 2006 | 05:14 PM
loneleader's Avatar
loneleader
My Check engine light has come on from time to time with code 34 & 41. My Chilton's tells me that the EVP voltage is above closed limit. This rig has a new EGR and EVP sensor.(actually both have been replaced twice within the last year)(From Napa) before the reading was too low. Code 41, according to Chilton could be either HEGO sensor circuit system lean, or No HEGO switching detected. I guess my question is "What is the HEGO?" and would the two codes be somehow related? Any insight to these codes would be greatly appreaciated.
Old Jan 4, 2006 | 05:39 PM
andym's Avatar
andym
HEGO is an oxygen sensor. You need a new one. Reset the computer after you install it and pull the codes again.
Old Jan 4, 2006 | 09:35 PM
loneleader's Avatar
loneleader
I installed a new Bosch O2 sensor not 2,000 miles ago. Could it have gone bad this soon?
