Sponsored by: Auxito
Wheel Conversion Adaptors
Old Jan 4, 2006 | 04:59 PM
LarryMac's Avatar
LarryMac
I would like to mount a set of 2005 F-150 wheels on my 2000 F-150. The older model is a five hole wheel and the 05 is a six hole wheel. Does anyone manufacture an adaptor that will fix my problem?
Old Jan 4, 2006 | 06:49 PM
cleevesj's Avatar
cleevesj
http://www.ezaccessory.com/
This site should help you out. I bought a set from them to mount my Mickey Thompsons on. I ended up using the same bolt pattern(5x135) with a two inch adaptor. It is not really recomended to use these except off road and it puts a lot more strain on the ball joints. Tire companies will not mount your wheels on your truck if they are on there either. So you will need to mount them up your self.
If this site does not help you out, do a google search for wheel adapters.
