Old Jan 4, 2006 | 11:31 AM
Ed89's Avatar
Ed89
I have a 1989 300-6 it just shut down on me had to have it towed checked spark but real weak,I cranked it over and it won't fire any way I happened to check radiator when I took the cap off it pushed the water out as if it was hot does that mean I have a head problem also seems like back pressure in the radiator. help
Old Jan 4, 2006 | 09:26 PM
srercrcr's Avatar
srercrcr
I would put a vacuum gauge on it to check if there's a dead cylinder. Or a compression tester.
Old Jan 6, 2006 | 05:52 PM
mcne's Avatar
mcne
If you take the cap off of a warm radiator COOLANT will come out/over flow! That is normal.
Old Jan 7, 2006 | 10:45 AM
Ed89's Avatar
Ed89
yes but it has been sitting for about a month after i tried starting it must be back pressure even when cranking over.
Old Jan 8, 2006 | 07:33 PM
Ed89's Avatar
Ed89
Yes but it is not warm it won't start just from cranking over it just seems like back pressure to push water out right. thanks for previous reply
