Sponsored by: Real Truck
Doors auto lock
Old Jan 3, 2006 | 07:43 PM
Slipperyrock's Avatar
Slipperyrock
Smile Doors auto lock
My doors are set to lock themselves when the truck starts rolling...which I like. My problem is they do not unlock themselves when the ignition is turned to off. Not a problem on the fronts because the inside door handles unlock and open the doors. The rear inside handles will not unlock the doors, you must either manually pull the lock up or hit the unlock switch in the front. I know in my old Toyota you can program this feature to work either way. Is it the same in a Ford? How? 2005 Lariat keyless entry.
Old Jan 3, 2006 | 08:05 PM
blueeyes2478's Avatar
blueeyes2478
I know you can provent them from locking themselves.But as far as i know you can not program them to unlock when you shut the motor off.
Old Jan 4, 2006 | 07:00 AM
rwilimo's Avatar
rwilimo
I had the same problem, I disabled the ford autolock and enabled the autolocks through my crimestopper remote start/lock system. Now it locks when you start moving and unlocks on key off.
